Hi
Has anyone successfully rendered Pyro using Vray?
I found another thread explaining it.
But i just get crappy result thats not convincing at all. Maybe its me doing something wrong?
does anyone know god settings for convincing results?
chreers
Rickard
I’ve played with it a bit and results were decent, I’ve seen a video made for Corona for C4D that explains the process very well, you can use 100% the same procedure also for Vray.
Ok, i will see if I can find that video.
Do you think it is a better idea to use Redshift just to render out the fire/smoke and comp it in?
Don’t know, here it renders very fast also on CPU, the simulation in my test was quite simple though.
