i am trying to “add to queue” method in C4D but the program does not render the cameras. How are you guys doing this? ![]()
Hey, try using ‘take manager’ if you are on r17 and above window-take manager. It works like magic, for more info I suggest for you to just youtube it.
Hey,
yup, I also recommend the Take system, if you are having sufficient C4D version for that.
But for me it doesn’t work under corona b1 (as I’ve seen in other posts you are using the latest builds as well), you should try it under a6.3, that is the last build I managed to get it working.
