Render Region from History/Load image, without prior rendering
Status: planned
Most of the time I make some changes into images once they are done, but when loading the image into the VFB the region render doesnt seem to work, could we have this option? Lilke I said, sometimes theres the need to edit a material or a mapping or a floating object X), this could be very practical to have without making a mask
Submitted on AHA Ideas (CMAX-I-65).
So you mean that on saving a CXR, you would like it to save any render regions that were active at the time of saving?
Submitted on AHA Ideas.
hi Tom, no no no no, what Im asking is a way to use Regions once we load a saved CXR into history, as you can see in the attached image, regions are not activated and we cannot create any, so If I just want to render an specific area, I need to render the whole image again, I think that I can create the region and Corona only focuses on that area but… then I need to create masks in Post
TY for the further details, that clears up what you are asking for :slight_smile:
It didnt occur to me that I could use Resume render in order to be able to use Region and then render the area, for the moment it does the job. hopely we could avoid this and be able to use Region when loading images directly from history
Nevermind I just test it it with Corona 12 update 2 and its working, thanks!!!
Now what Its missing is a way to preserve the whole image without using Resume Render.
@guest hi, this seems to be possible. Here are the steps:
  1. Render your image
  2. Save to history
  3. Render another image
  4. Click the edit button below your history item (pencil icon)
  5. Draw a region
  6. Make sure “Clear VFB between renders” is disabled in Render Setup > System
  7. Render
The result is that the history item is visible in the VFB and the region is rendering the current state of the scene.
Please let me know if this is what you needed or if it’s something else.
Submitted on AHA Ideas by Marcin Miodek.
Render regions are available when VFB is opened and history item is edited, without prior rendering.
However, even when “Clear VFB between renders” is disabled, everything but the region(s) will become black on rendering or resume rendering.
This specific thing is reported: https://jira-chaos.atlassian.net/browse/CMAX-1631
Submitted on AHA Ideas by Aram Avetisyan.
Hi Marcin
Thanks but this is not what I want.
When I saved the images into history and load other than the last one, when using render region to add new changes to the other view, Ill see the last rendered image (just like youre showing) what I need is to preserve the image that its loaded. To do so, Ill need to resume render to get back the image Im loading and then render region preserving the whole image with the changes I need to make.
Hope this make sense.
Submitted on AHA Ideas by PS I think I made a mistake with the image loaded in the original idea, I combined 2 issues into 1 :thinking: The issue with disabled Render regions has been solved as I mentioned on May.
Cant understand this reply.
But if theres an issue that has been reported, its fine by me.
Cannot view anything even creating an account in the link page.
Link is for our internal tracking, no need to do anything with it.
@guest thank you, I finally understood it and it is now logged for our devs as CMAX-2360.
I may have started with a video sample :sweat_smile:
AHA Ideas status: Planned.
Set during AHA Ideas to Discourse migration.
