Render Region VFB Shift Bug
Hello everyone,
during my last project I have notices undesirable behaviour of render regions. My resolution was 4096x2400 and when I was trying to align render region to far right edge it has shifted all other render regions along.
here video demonstration:https://youtu.be/Sig694ysaKo
I was able to reproduce it on simple blank scene with the same resolution. this time shift appeared to be heading downwards instead of leftwards. When I lower render resolution to full hd, this render region shifting stops. So it must only effect higher resolutions.
Daniel
Hi Daniel,
Well, this is interesting. I tried to reproduce it here but had no luck. Until we understand why this is happening, I thank you for bringing it to our attention.
Forgot to mention set up, Mac Os Catalina , both with corona are latest version.
Daniel
Thanks, I saw from your other posts that you are running Cat :wink:
It’s also working here. I suspect it will be an issue of the Mac version only…
I will try it on my Mac Book Pro. Maybe it is display resolution related.
Same issue on my Mac Book pro. No biggie, I can live with it, but still weird.
Hi Daniel, Since we have just released a new build for V5, can you install it and test this again and let us know the outcome?
do you mean hotfix 1 or regular v5 version, I see 2 version on google drive. Hotfix 1 still has the issue
Daniel
Thanks, Daniel, both the V5 and V5 hotfix 1 should be the same in this regard. We will test it on our Mac PCs now.
