hello!!! is it possible to save some files with the option “render region”, and of course, the region “drawn”, and use these files in queue, with the region in memory???
Hi celmar, this should already be possible! Have you tried to set regions in the VFB and saved the file afterwards?
There’s a little catch that the first hotfix will fix - you have to change something small in the scene after adding the regions or otherwise C4D won’t figure out that the scene was changed and you won’t be able to save it.
