Render resolution Cinema 4D (displacement etc.)
Hello guys.
I have a small problem with my renders, it seems like textures are in small resolution.
Example: Have a 4k map from World Machine, but when I hit render, they are not in 4k, displacement/normals are horrible (1000 segments on plane).
Is there any solution to fix it?
I saw guys with Octane, that they have a render resolution option.
Thanks a lot, Daniel.
Hello there :smiley:
If you are applying a displacement map in the Corona material then go under render settings → Performance and in there you’ll see the Displacement Screen size option. With it you can control how many subdivisions happen when you press render.
The lower you go (i.e from 2px to 1px) the better the quality the longer the render times / preparation times. You can also switch to world sized units to control displacement.
I hope thats what you’ve been looking for :smiley:
