render selected dont work in latest beta
REnder selected will only render an alpha channel, not the image
selecting a mask did the same, then when I swithced the mask off and on again it renders the image
It works here, can you give more details? What mode is Render Selected set to? (for me it was Viewport selection). What version of C4D and what version of Corona? I am not sure what you mean by “selecting a mask did the same”, can you break that down into steps on what that was? Do you mean full render, or IR, or both? (I tested full render). Is this on every scene or just in one particular scene? Thanks in advance for the extra details!
Hello @Barendby,
Thank you for reporting this.
However, we’ve been trying to reproduce the issue but we haven’t had luck so far.
Have you tried using the latest official stable release? (Corona 12 Update 1 Hotfix 1)
Does the issue persist if you use it?
If so, perhaps you may want to provide us with additional details like the Corona version you’re using, and additional screenshots or screen recordings showing the issue in action.
Looking forward to hearing from you soon.
Kind regards.
