It looks like the render selected feature does not work with Forest pro. (latest version)
Is it me or there are others with this problem?
Cheers,
Cheers,
See
Summary: You need to select the Forest source objects, not the Forest object itself.
In case of “Viewport selection” … well a very dificult task ![]()
Maybe it´s time for Ondra to choose Option B (even though I will miss how it´s working currently).
Good Luck!
Thank you, ![]()
This is also an issue when trying to render mask elements for FPP objects.
Is this a Corona issue or a FPP issue? I hope it can be solved so we don’t need to do these work-arounds!
Cheers,
This is not considered to be some issue atm, as I wrote above, see
especially ondras post.
Good Luck!
I see, thanks for the link. To me the default way it’s handled is not the most common use-case for us, so I would personally want this changed, but it looks like there are no plans for that.
