Render sequence with Vantage denoiser option
I find both Nvidia and Intel denoiser not giving very crispy render.. is there any way i can render using Vantage denoiser option in which it has slider control where you can control how much denoise you want and both Nvidia and Intel lacks that option..
Thank you
The Vantage denoiser is only for interactive mode.
Intel denoiser is definitely crisper than Nvidia - but have to use external software to sort out temporal/spatial noise.
Nvidia denoiser simply can’t pick up fine texture details and the blotchiness is distracting.
Looking forward to a more refined and finalized denoiser end result with the next update?
We’re trying to improve the offline render result with the Nvidia AI denoiser, but if such improvement is possible it will probably come after 2.1.
AFAIK an Intel developer is working on adding temporal stability too: Is there any chance to make this work with animations? · Issue #36 · RenderKit/oidn · GitHub
