When re-rendering a partial sequence from 3dsmax 2027, Vantage 3.2 seems to not actually save the frames in sequence, but just render 1 frame over itself. So if I’ve rendered a sequence 0-100 and then want to re-render only 50-100 (overwriting the original) by setting the “Frame range” under “Output”, it won’t overwrite the 50-100 frames. It just goes through the render process, but only saves out 1 frame. This is even more a problem when I’ve rendered 0-1000, but only need the last (ie. 100). Also checked the “Overwrite existing file”.
Hi LeePuznowski,
Are you using V-Ray or Corona and which version? I cannot replicate it on my end with V-Ray 7, update 3 DR2. There may be something that causes this. Can you record a video and setup?
Alexander
Hi Alexander,
Using V-Ray 7, update 3 DR2. I just tried the same scene and it is working correctly again (after 3dsmax restart). It has happened before (with a different scene), so I assumed it might be a user error or possible bug. I’ll keep an eye on it if it happens again and try to localize the possible cause. Thx for the quick reply.
When the saved image was getting overwritten instead of saving separate files, was the repeatedly overwritten file named with a frame number suffix or without it?
It was without the frame number suffix. So instead of Name.00100 it would be Name. Which initially confused me as I was looking for the original (overwritten) files with the number suffix and they weren’t in the folder anymore. So I originally had 0-600 and tried to overwrite frames 300-600 when rendering again and those were gone (overwritten, deleted?) leaving only the one file without suffix and the other original frames 0-299 that weren’t re-rendered. This was something strange I had never seen before, so not sure if something on my side was causing the error.
Thanks, this is a useful clue. We haven’t reproduced this issue, but we’ve had a couple of reports already. Even if we can’t reproduce it I have an idea for a speculative change that could fix it.
It looks like the issue could occur when you start an animation with live link already active as opposed to directly pressing the animation button without having linked in advance. Can you confirm this? This is probably what happened when you first rendered the animation once if you didn’t stop the live link session before redoing the render. We already have a fix prepared if this is indeed the case.
Yes. That’s most likely the reason. I usually go directly from a running live link to a sequence render as I prefer to quickly go through the timeline with live link running before I start. If I get a chance I can try to test that. Thanks
We made a change in 3.2.1 -- can you check if you still have the file overwrite (missing suffix) issue with the latest version?
