render settings from file
any way we can have a grid point at saved render preset and use that at render time?
often i have multiple grids with same settings, and if i change one i have to go in a do it for all others
cheers
Harv
In the Rendering rollout there is a Render presets button which allows you to save and load a preset with the render settings. Will this do the job?
i know about that, not quite what im after
i want each grid to load a specific preset at render time
so i can have multiple grids loading the same preset at render time, rather than me manually loading a preset for each grid i have
