render settings not saved with scene
Has anyone encountered this issue upon saving a scene, the render settings revert to default on opening.
Latest nightly vray 3 build. vray_adv_30504_maya2015_x64_25041
What could be causing this?
PS I also “set preferred preset” as a new default, but this also get ignored even though it is ticked!
Do you have any referenced scenes? Is it possible that one of them drags in a vraySettings node?
All assets in the scene are assembly references so no standard maya referencing going on. I have turned all to locator so no scene file are loaded.
When I select the vraysettings node in the outliner i get this error…
select -r vraySettings ;
// Error: file: C:/Program Files/Autodesk/mentalrayForMaya2015/scripts/AETemplates/AEmentalrayNewMessage.mel line 91: Cannot use data of type no type in a scalar operation. //
First time I see this… do you think you can get us the scene?
yeah sure its 2.67meg so ill send via email
here is the scene
ok i can post it here as there nothing referenced in
AD_village_workshop_0013.zip (182 KB)
I was not able to replicate the issue using your scene file. Tried with Maya 2015 and Maya 2015 Ext 1 and V-Ray _25041.
Do you use any additional plugins for this scene (Mentalray for an example)? If yes, try to unload them?
Maybe we can run a test using the whole scene including all reference files? Feel free to contact us via our ticket system : support@chaosgroup.com for FTP access.
Can i just ask that did you apply render settings then save the scene. Open again and see if the settings remained?
I wont be able to upload all assets NDA in place.
I will unload mental ray as we dont use it anyway.
Thanks for your help
Yes, I did > Opened the scene > changed few settings for AA, GI, Render elements > saved the file (tried with just a Save and Save as..) > exit Maya > opened the file again
