Render Setup JSON: Nothing registered under "sceneAOVs" key
I’ve found 3 issues with V-Ray and Render Setup;
# 1. V-Ray Render Elements are not included in the exported Render Setup JSON file under “sceneAOVs”. Major issue!
# 2. Code not suited for Render Setup is being run when adding a render element directly to a render layer which is not the masterLayer/defaultRenderLayer.
# 3. You cannot double-click Render Globals → “AOVs” when V-Ray is loaded (it should take you to the Render Elements tab)
______________
# 1. V-Ray Elements not included in RS JSON
I’m on Maya 2017 and I’m exporting the Render Setup JSON for parsing outside of Maya. This is great as it offers us the possibility to spool render jobs from a custom standalone application which doesn’t require Maya to be opened at all.
However, I’m noticing that in the JSON, the “sceneAOVs” key’s value is empty when using V-Ray. If rendering with Arnold, data for the masterLayer AOVs are stored here. I would like to request V-Ray Elements for masterLayer to be added to the “sceneAOVs” key’s value in the JSON. This is a major issue for us.
# 2. Code is being run meant for legacy render layers
Also, I’m noticing that V-Ray currently seems to use code meant for the legacy render layer system when you create a render element for a non-masterLayer render layer. This can be reproduced as follows:
1. Open Maya 2017
2. Create a new render layer, click its eye icon and then enter its render settings.
3. Enable V-Ray and create a render element.
4. The newly created element automatically has its “Enabled” attribute unchecked and the attribute itself is marked as orange in the attribute editor. However, this override is not picked up by Render Setup. Instead, this probably only works if you’re using the legacy render layer system (can be toggled in the Maya preferences).
# 3. Cannot invoke render elements tab from Render Setup Window
When I double-click “AOVs” in the Render Setup window, nothing happens. If Arnold is loaded, I’m being taken to its AOVs render globals tab.
1 Hopefully this get fixed as well
2 I’ve been dealing with the same issue which is super annoying actually, it would be nice if Vray can pick up the override in the new render setup. This is major slowdown in production.
1 - we’re looking into this now
2 - what vray version are you using - I remember we did some changes there to improve that behavior, but again - there could still be bugs
#3 - it doesn’t work for the moment, but I’ll make a note to possibly fix it.
Thanks for having a look. V-Ray 3.40.06 build 27073 for Maya 2017 on Windows 10, 64-bit.
on 1 and #3 - we did some research and found a way to implement support for this. #3 would be easier than 1 and we’ll see what can go into the next service pack, but we can’t make any promises for now.
2 is actually already fixed, but it’s only in the nightly builds (not the stable nightlies though, the nightly-nightly builds). But it will go out with the next service pack.
Many thanks for investigating this, Alex!
That I totally understand. I have created a custom exporter/importer for the render elements, as we are getting ready to adopt the new Render Setup system. However, it would be very useful to get proper support for 1 at some point.
Ah! I actually try to stay away from the nightly-nightlies, so that’s why I wasn’t aware of that. Nice!
Actually all of the three points you made are now fixed and in the nightlies. They will, of course, go out to the next official release.
Hi Yolov and thanks for the update. That’s great news!
Do you know if these fixes were added to the stable builds?
No, they’re in the nightlies and in the branch for the next release. We’ll have stable nightlies from that branch pretty soon. It would be greatly appreciated if you could give those a try and let us know if they work as expected. If you don’t want to try the nightly-nightlies, I’ll let you know when you can get a stable build with those fixes.
