Render Setup window "An error has occurred and the application will now close"
When i open, config and try to close the “render setup” window I get the error and the program closes. I have Corona 8 and 3ds Max 2023.
capture error-corona-render-1 hosted at ImgBB — ImgBB
There is a bug introduced in RC4 which causes 3ds Max to crash on scene save. I think it’s related to your case too. The fix will be in the next build. Disregard that, Frood gave correct answer below. The solution to this would be to either rollback to previous 3ds Max update, or wait for Corona 9 which should be released very soon. You can also try to set some other renderer as default in your render setup window and it should prevent Max from crashing.
This is Corona 8.2 and presumably that Max 2023.2 bug:
https://forum.corona-renderer.com/ max 2023.2 crashing when closing render setup dialog #msg203939
Good Luck
I will not happen in V9, which is scheduled for Monday. :smiley:
