Render stamp does not work with TeamRender.
Version: 6.0 daily Ju 16 2020 macOS Catalina
The render stamp won’t save (even without team render) when saved through the C4D native save processes. The solution to this is to add a “Render Stamp” Multipass, then be sure to enable saving multipasses (should work for both save from PV, and save from TR - if this is what you mean is not working via TR, let us know! Also would be good to know in that case what happens, there is no render stamp, there is a render stamp but certain values are missing, etc.). Hope this helps!
Thanks for your reply.
I need the Render Stamp with the Text Copyright… (on Team Render).
Thank you. it works
