Render starts itself when file is open
Hi
About month ago notice some strange thing. Sometime when I open file corona automatically starts render as soon as file opened by Max. Now I use 2016-03-12 build and had the same thing happened few minutes ago. It’s not a problem to cancel it, but for example now I had another file rendered in the same time and I didn’t understand why rendering goes so slowly until I switched to second Max and saw that rendering is going there also. It doesn’t connect with some particular files, as I said it just happens sometime
I don’t recall anything like this. Can you send us any file where this happens?
I tried to open again the file which started to render, but second time rendering didn’t start. Now I’m working with this file and it’s been saved many times. But I can send it anyway. It’s quite big - archive with all proxies 230 Mb, but probably I shouldn’t take something away from it… Should I send it to mantis?
If you are able to reproduce the same thing on a smaller file, that would be great. If you are not, then please upload the original file to mantis.
I can’t reproduce this in smaller file unfortunately…
There is limit of file size 110Mb on Mantis. I’ve uploaded it with Private uploader as 1457960089_66-011YITJoensuuRantakylpvk.zip
I cannot reproduce this… does it happen also in the latest RC? How often does it approximately happen? Is some IR involved?
