Render stuck at transforming vertices
Hi we’ve been having issues with this file. The render gets stuck at transforming vertices even though there isn’t any displacement modifier or displacement in the materials. I’ve tried to isolate the issue but haven’t figured it out yet. We are using the latest version of Vray 6 and 3ds Max 2023.
I’ve uploaded the file here:
https://easyupload.io/qvqvdr
Thank you!
So i’ve found the problem.
I’ve been using this script in the Physical Camera:
Apparently Vray does not like this for final renderings, but ipr its fine. I’ve used this modifier in Vray Physical Cameras without issues but it seems to be an issue with the standard 3ds Max Physical camera (which is used here). After deleting the modifier from the camera, the scene renders as normal.
It’s just a thought…maybe try switching the camera type to ‘perspective’ in the dialogue options.
This worked for me when recently using camera mapping, which was having issues with the default setup.
We are currently working on a similar feature.
