render taking 3 hours
Hello
i just design one of the project which has not much detail as has to be but its taking lot of time to render.. image size is Default HDTV and 3 hours renderings to reach 5.00 noise and 75 points in denoise .. whats the solution ..? m late to submit my project
Impossible to say without seeing the render, as could be all sorts of factors depending on everything from scene set up, to lighting, to scatters, to textures… but without seeing what kind of scene you are talking about, no advice can be given, sorry. Also, which host software (and version of it), which Corona version, what hardware specifications?
You can always submit an image, or the scene, via private uploader if you can’t share here on the post. See https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006-how-to-report-issues-3ds-max which has links to the private uploader.
