Render texture path not loading correctly
When I render a model, which is already previously rendered on my or other computer, textures do not work properly.
The path to the texture image completly changes to an uknown location. When I change path to the correct one it still doesn’t really help.
If i wipe all of the V-Ray information from the model then textures are good again but than i need to start again from scratch.
Is there a way how can I fix that?
Hello, Eva,
A good solution is the File Path Editor which you can use to manage all your asset files in bulk. You can find it in the SketchUp Menu > Extensions > V-Ray > File Path Editor. More information about it is provided here Chaos Docs.
Kind regards,
Natali
Thanks for the suggestion. I tried it out but it still didnt fix my problem.
I can repath the textures but alpha is not working properly.
For example leaves on the trees or 2D trees have white instead of see through.
Even if i repath all of my textures and it showes the proper path to the texture file it doesnt seem to work.
Are there other things i can try to fix it?
I made some screenshots:
model wiped of vray information
