Render the same object 3 times with 3 different materials in 1-go
Hi everyone!
I was thinking, is there a way to render out the same pillow in 1-go, 3 times with 3 different materials?
Thanks in advance! :smiley:
you could use a CoronaSelectMtl and loop over each material.
As Clemens wrote above. If you don’t want to write any script (I can’t write any myself), you can key-frame (animate timeline) CoronaSelect and Batch-Render (native Max or Pulze)
edit: Avi mentioned the name of the plugin.
The solution mentioned above by others can work and you can also look into pulze scene manager for doing similar things.
