Render to fields problem
Hi there,
We’re in the middle of a huge project and we need to render all projects with fields for tv. The problem is that when we turn render to fields option on, some frames get the top part black.
Since we’re starting the rendering process, if you have any tip about this, please share :slight_smile:
Thanks in advance,
Rui Romano
I’ve run into the same, if not a similar issue. Turning off show calc. phase in LC fixed the problem for me. Hope that helps
U just saved my life, hehehehe!
Super thanks Austin :smile:
cheerz
I would like to know if this problem is solved in current Vray RC2 version. Can I have Show Calc. Phase turned on when rendering to fields ? Thanks in advance.
This is corrected, yes. The “Show calc. phase” option will be automatically turned off if you render to fields.
Thanks, i had the same problem. hope this helps.
