How do you edit the parameters of a map when you want to make a Render To Texture. I use to do it many years ago with Mental Ray but now i have to do it with V-Ray.
I would like to render several AO map with differents value (ex:3cm & 20 cm) with VrayAO and make some extramap for mask with VrayExtraTex.
But when i add them in the output list, i don’t have access to their parameters.
Is there a workaround or something i’m missing ?
Thank you
