render to texture (Texture color problem)
Hello friends, I baked a texture with two Scanline and Vray engines. The upper one is vray and the lower one is scanline, the lower one is exactly the same colors that I gave in the materials, but in vray, the colors are rendered badly. Do you know any solution to the bake diffuse texture in Vray? I also read the Vray document.
Mind if you send us the scene so we can troubleshoot?
