I have a little problem. I’m trying to bake a building with three machines, one host and two slaves. With basic production rendering the image looks just fine but when I try to render to texture, the buckets gives a different color. This happens only with one of the slaves. Host and another slave is doing just fine. Textures are transferred correctly and V-Ray messages gives no error. It looks like there is something wrong with gamma but all the 3ds maxs has the same gamma. I think nowadays 2.2 gamma is default. All the computers are also identical and all them has max 2016 and the latest v-ray.
Any suggestions what could be wrong? By the way, the one with the error has only render node license and two of these has full license.
Thanks for your answer. Just before I read your post, I got it working. I started Network rendering via back burner just for that one machine and the result was correct. Then I tried to render with distributed rendering just as before and now it works like a charm. I don’t know what was wrong there…
I had some nightmares with embree and RTT, so I’ve been told by the support to never use it as vray has bugs with RTT and embree.
I have reported the issue but it isn’t fixed yet, so best to keep it disabled when RTT.
