I’m trying to bake some maps from a high poly door made from separate parts (screws, hinges, door knobs, etc), to a low poly single object (with several elements). The normal maps turn out fine, but all other vray elements show that the item projecting is taking into consideration the item it is baking to in the render calculations. So there’s dark spots showing up in the map where the low poly object crosses over the high poly one, even with the cage set properly. I’ve tried applying an invisible material to the item being projected to, push the cage out to extreme amounts, turn it to not renderable (which makes Max unstable until you restart). I’m at a loss as to how I can fix this.
Anyone have any tricks to get this to work? Am I missing a toggle somewhere so it ignores the low poly object?
I think I got it figured out. VRayDirt was the culprit. VRayDirt seems to take into consideration any object around it, including those that are being projected to. “consider same object only” or setting up Excludes doesn’t work as you think it would; it still considers the object to receive the mapping. But, if you check “work with transparency” and make sure the material assigned to the low poly object being projected to is completely transparent at the time of baking it works.
Not sure if this would be a bug or not, but if VRayDirt could be updated that it ignores anything with the Projection modifier on it?
I managed to replicate the issue on the scene you sent me and I’ll report it as s bug into our system.
Will let you know when we have progress on the subject.
Look like I replied too fast, the issue has nothing to do with the V-Ray Dirt material and I can confirm that Consider Same Object option works just fine.
This is how the bake looks like when Consider Same Object is disabled:
.. and here how it looks like when it is enabled:
As you can see the Dirt(green color) on the second image is not influenced by the low-poly geometry as it was on the first image.
The real issue here is that V-Ray doesn’t make the geometry being projected onto invisible for the camera and V-Ray sees it and render it.
I’m not sure how 3dsMax native render handles this case but I suspect that they automatically make the geometry invisible when Projection is enabled and only render the geometry being projected from.
Actually it doesn’t work with MentalRay as well, so it might be a option that should be user-configured.
Do you know a render engine that renders such scenes properly?
If I recall, scanline does it properly, but I haven’t used scanline in ages for any scene setup to verify. I’m now wondering how everyone else is baking their VRay (and I guess Mental Ray) scenes to low poly without these artifacts? If they are using the same workaround as I am by making the low poly object invisible, or if there’s some toggle somewhere that happens to make it work properly?
