Can you render an animation inside a TV in vantage as is something moving or as an image sequence like the TV is playing a show?
Thank you
Hi frankc,
Yes, with 1.8.0 update image sequences can be rendered inside Vantage if they are exported in the vrscene. The way animated image sequence is created depends on the host app you are using.
Alexander
How can I apply the image sequence? As material in vray and apply as bitmap, it will read in chaos vantage? Thank you
