Render Very High Resolution Image using Vantage
I need to render a very high resolution render, approx. 50K in resolution.
Is there some way I can split the render into parts and render using Vantage?​
This is not supported. The maximum resolution in theory is 16K, though the Optix denoiser has a lower limit and you may run out of memory anyway. You should probably use V-Ray for such huge renders.
