Revit 2019, Enscape 2.7.2
Worked on this for about 6 hours, and cannot get a rendered view to match the Revit camera view. Perspective is off, camera location is off, extents are off, and lighting is off.
How do you get them to match? X(
Welcome to our forum - I’m sorry to hear you weren’t successful yet with matching the views of both Revit and Enscape. First off, you are making use of our View Selector located right next to the Start button already, correct? Revit does crop the viewport, so it will look different to the output in Enscape, and the output will also depend on adjustments like the “Field of View” which you can adjust in the General tab of our Visual Settings, definitely give this a try as well to help with the matching.
When it comes to the lighting especially, is there a chance you could please send me a screenshot (or a few) for better understanding? Are they perhaps simply not visible during daytime, because often times the sunlight outside is actually so bright, that the interior lights may not be visible if you do not turn up the brightness substantially.
This is modeled after the real-world behavior though.
