We are switching from 3dsmax to Houdini recently.
There is an issue that our render farm machines start rendering even some files are not loaded, leading to randomly missing models/textures.
A little background of our setup:
Workstations and render farm are using Houdini 19.0 and Vray 5
The rendering management software is Deadline.
We store models (mostly Alembic file) and textures (exr udim) on two separate local-network machines, and the network speed is not very fast.
Vray for 3dsmax has no such problem at all.
I would like to know if there is some kind of settings we can set to prevent the problem.
Thank you for your time.
edit 1:
I take a look of Deadline logging. When the files are missing, there will be a warning message:
V-Ray: Bitmap file “\\xxx/xxx/xxx.exr” failed to load: cannot open file: 1: Failed to open file: no such file
Is there anyway to stop the renderer if missing files, or to reload the file?
> After few tests, I can confirm texture missing doesn’t count as missing asset.
It should count. Are we talking UDIM or file names with tags/frame number?
You could also try setting VRAY_UNC_TIMEOUT env. var. on your render nodes to some higher value then 5000 (timeout in milliseconds).
For us the environment variable seems to have fixed the issue. I set it to 10 sec instead of 5.
Since doing that we haven’t seen the issue again.
I don’t know why it would be timing out - our NAS is usually extremely fast. Especially cached files are served up in milliseconds.
@bdancer could this help on linux as well? We got the sporadic error where textures randomly doesnt load for some objects in the scenes on random frames
May I know if there’s any update about this issues? This really affect the the production speed and i am thinking if Vray is not ready for proper VFX production…
Thank you for your reply.
The issue that I encounter is not related to IPR and missing geometry but failed to load all the UDIM textures before rendering, the textures are not fully loaded before rendering started. This happened in both Vray for Houdini 19.0 and 19.5. We are frustrated because the issue happens quite frequently, almost 50% of the frames would have this error. Each time we need to check each frame to find out the frame with the error and resubmit until all frames are good.
We’ve been using Vray for 10 years and we are very pleased with the performance and quality of Vray, thus we decided to keep using Vray when we change our DCC from 3dsmax to Houdini but now I am really worry about this issue. The support team said they can’t provide help since we are using Deadline for the network rendering. Could you pleaae advice how should we solve this issue?
> Am I able to add this in my houdini.env and test it in the version that i am using? Is it a new feature?
I was sure you’ve already tried this since I’ve suggested this a few answers above, but with the version you are using setting it to 0 won’t completely disable it,
but you may try setting some big value (value is milliseconds).
With the latest builds setting it to 0 will completely disable timeouts.
We just tried it in the render farm, it doesn’t decrease the chance of failure texture loading, but on the other hand, some of the workstations would be failed to render any texture.
May I know when the nightly build will be ready for download?
