Rendering 2d people w/toon material question
I’m trying to render 2d silhouette people w/the lines showing, I can only get the outline to show up, is there a way to have the inner-lines render that show the arms etc.
Thank you.
Hey @Jeepin72 ,
Depends on how are the 2d people created. They would need to have some faces so you could group them depending on how you wish the inner lines to show. I’ve prepared a sample recording for you to check, hopefully grouping the individual components should do the trick for you: http://ftp.chaosgroup.com/support/sc…7_16-37-51.mp4 Use double-click to select the face and all its bounding edges.
