Rendering and saving settings
It seems that any “custom” render settings are machine/user based and do not travel with the file. Is there a way to have various users load saved render settings from other files and users?
The setting presets are saved in files in the folder MyDocuments/Enscape/Settings. (MyDocuments/Inreal Technologies/… if you have used an older version) You can copy/paste them to other computers, although you should make sure that both computers are using the same version of Enscape. This is all we can offer until we find time for settings inside a file or even specific to a view/scene.
Have a look at our corresponding knowledgebase article.
Looking for the material name to brick and block, exist any similar?
Regards
@Efragalicia_1 thank you for your feedback!
So far we don’t have such a keyword for a brickwall or sth. similar with bump map etc.
You would have to apply a material with brick texture and add a keyword of your choice, like fabric etc.
ok, I’ill try
thanks
