Rendering Anima 4D animation in multiple camera cuts
Hello
I’m very new to Anima and have a lot to learn about Vantage. My current project requires rendering out numeous short clips from multiple cameras. Since batch rendering multiple cameras does not seem to work, I set up a sequence of camera clips in the Animation Timeline and render out the frames as one long sequence (sometimes with custom frame ranges). In After Effects I chop up the render sequence to isolate each camera clip (for transitions, time-remapping, and post effects etc). As you can see in the link, there will be occasions where the Anima 4D animation of people will reset back to frame zero at some abitary point along the timeline of the camera sequences.
So firstly - is there are way of switching to each camera shot so that Anima 4D sequences start from frame 0? The camera moves were set up in Vantage, not 3DS Max. If anyone has advice on rendering out multiple camera sequences, I’d love to hear your thoughts.
Example here: Anima_Glitch.mp4
As far as I know is to keep all the clips within the frame range of the anima peeps exported animation. So if your Anima animation is 600 hundred frames, you can only have two 10 sec clips rendering.
OK thanks @Luma3d . I think what that means is I’ll need to delete all of the camera animations in the timeline except the one I need and render that out individually to ensure the Anima 4D animation frame 0 starts with the camera movement. There are a lot of 3-4 second duration shots in my animation, so that’s going to be really tedious.
