Rendering Animation with Alpha + Bloom & Glare
I am rendering an animation with alpha. I am rendering as an image sequence. What’s the best file type to use? I’ll be bringing it into After Effects for compositing. My current settings aren’t bringing in a proper bloom and glare effect. Also, is the only way to render animation through C4D’s picture viewer?
I personally use PNG or TIFF. I haven’t had any issues with bloom/glare not coming through using PNG.
The bloom and glare issues could be coming from the 8 bit depth you’re rendering at.. Use 16 bit!
TIFF allows 32 bit depth but i think the files are a bit larger.
Ahhh, that could be why! I was rendering in 8-bit.
Thanks!!
Okay this still isn’t working properly for me. I have attached a scene file. If you render it, you’ll see it saves 3 files:
Virtual Beauty
Bloom Glare
RGBA
The RGBA file does not have bloom and glare coming off it, however the virtual beauty pass does. I added a Bloom Glare pass, but it doesn’t seem to be doing anything.
I’m trying to render an animation with a custom background I made in After Effects. It would be nice to get that bloom and glare. What am I doing wrong?
bloomglare-alpha.c4d (380 KB)
Anybody?
It should be possible to render:
-the “main” output consisting of beauty + bloom and glare
-beauty without bloom and glare separately (virtual beauty)
-bloom and glare pass only, which should save the bloom and glare on a black background - easy to composite
If something is not working right, please report it as a bug.
The Bloom & Glare pass is all black. Will report as bug.
I also have issues with the Bloom & Glare pass, the effect comes through in the image but the dedicated pass is empty
Is this a bug or a mistake on my part in setting it up?
Seems to be a bug, the bloom and glare pass in C4D shows as black. It’s on the bug reporting system (Mantis) : https://corona-renderer.com/bugs/view.php?id=2667
Greetings everyone. I’m noticing that this error is still present in Cinema 4D 2023 - Corona V9. Any hopes of getting it sorted or has anyone found a way around it.
Hi there, this seems to be working for me. Is everything set up correctly for you?
Seems to work for me on Mac C4D r25 and Corona 9. Maybe you didn’t select the Multi-pass save section?
