Hello everyone!
I am rendering an interior scene where I have some dark areas that produce weird flickerings; however, I managed to get rid of about 90% of it by completely removing direct light passing through a translucent object (in this case hanging kitchen lights)
normally in Vray, I would just use the “include” function in VrayLight to fix the problem, but this feature is not yet supported in Vantage.
these are also things I tried to fix the problem but had no effect on the flickering :
- fiddling with clamp secondary rays and ray termination values
- disabling reflection/coat/ etc..
- increasing Samples to 2000
- using VrayOverrideMtl
the way I tested all these scenarios was to render 4 - 6 frames and compare them together, flickers are so obvious they change frame by frame.
I have attached the video named " test_2.mp4"
samples: 600
fps: 30
resolution : 2560 x 1440
here’s my light setup, which passes through a two-sidedVraymtl that I found to be the main cause of flickers.
I could use some tips to work around this problem and get rid of flickering without removing my translucent objects.
Thank you and have a blessed day.
