Rendering animation with LC and Brute Force
In the past, I’ve used LC as secondary GI and IRmap as primary. On a current job, I’d like to see the quality by using Brute Force instead of the IRmap.
Am I correct in assuming that I pre-calc the LC (in flythrough mode) in exactly the same way as before, and then use that saved LC file to render all the remaining frames, but use a ‘per-frame’ generated Brute force method for Primary?
This is correct, yes.
