I don’t know if my computer is dying but when I render, the screen freezes and then suddenly popped back in. Sometimes the screen freezes and goes black then the screen comes back as normal but the 3ds max view-ports a greyed out.
I have a pretty good computer. Don’t know why its happening. Have you guys had this problem?
Ill keep testing but this seems to happen mostly in bucket rendering mode.
Thanks guys. Man this is 1 problem solving activity after another. I set up distributed rendering but now my computers crash when I render.
I hired a network rendering licence and purchased a computer for network rendering - it was hard to set up and then I discovered that there is no IPR support. Now when I use the production render button my computer has a heart attack.
I want to specify exactly what is wrong so I can fix it.
My computer even crashes when I use VRay benchmark.
I stopped using DR years ago. I opted for one large machine with a ton of cores and a ton of RAM. I spent more time managing the servers than creating images.
So - I have no crashes at all when I unchecked multi-threading on my workstation. My CPU works away at 17% while the slave works its ass off.
Im glad this completely stopped the crashes.
Now I just have to figure out a way to allow multi-threading, assigning an amount of cores so when I render the workstation CPU runs at about 75% load with the rest available to run the computer.
I would like Vray to implement some control over the amount of cores used in rendering. I don’t know if disabling cores using Affinity will also make other tasks in 3ds max slower, like transferring the files to the slave render nodes for example.
.I will try to get rid of these artefacts seen above. Then I will assess if DR it worth is after I get some successful renders going. For now it has been very painful and potentially pointless. If it does not work out I will ask Chaos for a refund for sure.
It was a missing plugin not installed on the slave. So it works.
Thank you everyone for your help! Thank you Bobby.
Since I cannot afford a monster, I will save up for one. in the mean time I will test DR for maybe, 1 more week. Ill give it my best effort. Hopefully its viable.
