rendering glitch?
Im running into problems…Vray isn’t rendering the model correctly. Surfaces get jagged and turn out all over my models. Ive had this problem on many models.
Re: rendering glitch?
BTW when viewed in model space, you can see that the surfaces that are bound dont align with the edges. Is it a video card problem or dispay setting? Im running vista 32 bit, 2gb ram
If the problem is happening in rendered images, then your render options might not be set properly. If the problem is happening when you’re working in Rhino, rotating around the model, and modeling, V-Ray has nothing to do with it.
here is an image of one outcome…
Did you check Secondary Ray Bias? Also you may have duplicate objects, if yes delete them :wink:
