Hi everytime I need to render an image in 8k
But every time I try to render 3dsmax crashes or closes.
Is there any solution?
I have 32gb of ram
I have 32gb of ram
Get more Ram. 64gb is the minimum nowdays as models and textures get bigger and bigger.
For now you can try to check the “conserve memory” box in the performance tab of corona settings. Should be able to render but will take longer.
You can also downgrade your scene by optimizing your geometry and resizing textures, optimizing vegetation scatter, disabling displacement etc…
