I am trying to render the inside of the ocean like this.
I placed a plain water surface above the camera, with black boards around it.
However, the rendering screen is dark, and the light does not reach the water properly. Even if I make the surrounding black boards white or change the exposure, there is no change.
Is it impossible to create a scene in a wide space like the ocean?
Try increasing the absorption distance under the Media options rollout. This controls how quickly the light entering the water becomes black.
To get “real life” simulation, you would also need to enable Scattering under media options since there are tiny particles in the water. This will however result in longer render times.
