Rendering is calculating again even when I stop it...
Hi All
As usual when I want to stop a render I click on “Stop” and the render is finished.
But today there is a big problem : I click on Stop (or Cancel, it’s the same result) and the render is going again : Building ACC Structure, Computing secondary GI, Rendering initial pass and render the image again and again.
I can’t stop it, only when I close the application (3dsMax)…
I have the last Corona version 1.2.
Is it a known problem ?
Roland
Hi. Do you use AO in the scene? If so, what happens if you disable it?
I had a similar problem caused by AO, that is solved i Daily Build.
Maybe this? https://coronarenderer.freshdesk.com/support/solutions/articles/5000570006
This is exactly what happened ! it’s resolved for me, thanks a lot Maru :wink:
And yes, Proh, i use AO in my scene, but in some shaders (CoronaAO). But the problem obviously did not come from there…
Thanks to both of you
Roland
