Rendering is generating tons of new folders
I recently switched to using relative filepaths in Max on my system so I think that may be the cause.
I’m using a folder called RENDER to try and troubleshoot some of this.
On the Common Tab > Render Output, I did not check “save file”, but did put a filepath and filename in. RENDER\Scene_02_test.png
V-Ray Tab I have checked Separate Render Channels and Separate Folders. RENDER\Scene_02_test.png
I have 3 render elements.
When I render it creates a new nesting folder structure, most of the time it is completely empty. This didn’t happen previously. I think there is there something obvious I’m missing. Or should I just go back to absolute pathing?
Make sure you save the .max file in the project folder as well.
