When rendering the above objects which does set diamonds, will I need to turn on Caustics in order to get the diamonds to “sparkel” properly?
did you forget to attach any image, or is just me who can’t see it?
now i didn’t forgot, but there is no image yet:)
I was just asking so i know how to approach my setup, then images will follow;)
fair enough
I thought there was a picture showing them above objects.
anyway, if by sparkling you mean dispersion, you may want to have a look at this thread:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=35110&highlight=dispersion
thanks rivoli
hope to post a test rendering by tomorrow some time
don’t forget to build nice studio setup for this. I did mine based on real one:
http://www.tabletopstudio.com/documents/swarovski\_crystal\_photography.htm
Great link Lukx! Thanks.
studio setup
Hi lukx
Thanks for the great link!
Hope you don’t mind me asking some questions on your setup.
Did you modeled a shape similar to that of the EZCube and what type of material did you then attached to it?..something along the line of a inner curtain perhaps?
Did you also placed your two side lights on the outside of this shape as per the real life example?
If you didn’t follow the route of creating a “box” similar to the EZCube, how did you go about creating a soft light effect for the side lights.
Lastly did you experimanted with 18 led light setup?
Thanks!!
wow,
what a great tips on that webpages
thanx a lot Lukx
