Hi
rendering a large file, done all the setup as per instruction BUT no data is output (RIFile::WTVrayInfo) No file stream, unless I turn on the Memory Frame Buffer, which sort of defeats the object ?
Any suggestions ?
Thanks in advance
Spike
Hi
Any suggestions ?
Thanks in advance
Spike
Do you have V-Ray Denoiser involved in this setup ?
Hi
Turned it off and it seems to work (BUT I have just rendered a smaller resolution, to try it out).
I will try a larger resolution later.
Denoiser is disabled automatically when setup a render without VFB in the Next beta
