Rendering Quality
I am rendering an iamage. I adjust the quality to high+. However, the image is still vague. Does anyone know how to deal with it?
Thank you.
The quality of the image is not a problem, you should be concerned by other things. Look online for some reference photos of building like your, then try to understand the difference with your render:)
Noise limit at 0.03 and denoiser enabled should create a clean image. Noise limit at 0.01 can be used without denoiser, but it’s much slower. For more speed you could try 0.05 + denoiser.
Thank you for the suggestion.
Thank you.
I still have a problem with quality. The picture shows the rendering setting.
Thank you.
Disable the antialiasing filter and enable the denoiser.
Hi @ziyao_zhang ,
Another thing I’d consider is rendering a bigger resolution image.
You will see a much crisper result this way.
The image can then be downscaled in post if you specifically need a smaller image.
Konstantin
