Rendering selected Object Gbuffer ID affected by region
Previous post: https://forum.corona-renderer.com/ Render Selected not visible to Cameras
I am making this post in relation to a previous feature request that I made and found a work around for.
The bases of the request was to use an object in the scene as a render region using a gbuffer ID. The work around uses an object with a material set as transparent so in theory it should just render everything within it’s form. Great for patch rendering animated scenes with cameras and objects moving.
So I did some more testing and have an issue as the render behaves differently when rendering selected ID is set. The render takes long time and renders to a much lower than expected noise threshold.
All attached renders are set to 40 passes, and I would expect it to reach around 2-3% noise. The first render has render selected by Gbuffer ID and the ONLY difference in the second render is that I drew a region tight in around the rendered area. The third render is EXACTLY the same except the region covers the whole frame.
First Render (no region selected ID only)
render time -26 minutes
noise level - 0.96%
Second Render (with tight region)
render time -7 minutes
noise level - 2.63%
Third Render (with full frame region)
noise level - 0.96%
The second image is how I would of expected the first image to also render. In fact I would of expected all 3 to render the same!
Although there is a time saving in set up time it leaves relatively little point in using gbuffer instead of rendering many regions.
I would expect a whole frame to render in about 45 minutes. We have had similar experiences with render time in the past using Obj ID (never been trying it with a transparent object before) but never really investigated it any further other than rendering to a noise threshold which for animation we found flickery.
Why would a region bigger that the object effect the render so much and Is this an expected behaviour? Has anyone else experience similar? and most importantly is there a solution (other than regions)
Thanks for your time.
So you are rendering with:
  • a pass limit
  • “render selected” used and set to gbuffer ID
  • region on/off
— internal notes —
Waiting for more info, and will log this case then.
Here are some similar things:
https://forum.corona-renderer.com/ Slow Render Selected
id=257367101 <— cancelled
id=251256407 <— active
Thats all correct Maru, thanks for looking into it.
I don’t want to use a region but completely by accident noticed the difference it makes.
Just read the post you linked to and it describes exactly the same behaviour.
Glad it’s not just me. A fix would be awesome :smiley:
Fixed in v6 DB 2020-07-21
