Rendering settings
Guys,
Anyone please help me out for high quality pixel settings for corona interior render because whatever i do while zooming output is not that much clear ,it pixel breaking…:⁠-⁠|:⁠-⁠\
Corona by default should give you the best quality available. Could you show some examples of “pixel breaking”? It’s hard to imagine what you are talking about, maybe you are simply zooming in too much? :]
how to configure Corona settings to reduce noise while rendering, how to optimize the scene and lighting to improve rendering quality, and what techniques to use when zooming in on the rendered output to maintain the level of detail and sharpness.
There’s nothing to configure, really. As i already said, Corona should give you an optimal quality straight out of the box. There are some controls in render setup>performance tab, like AAvsGI, LSM, MSI and few others, that can be tweaked to try optimize render speed in specific situations, but it’s very scene dependent and what’s work in one scene, might worsen things in another one. If you don’t know exactly what each of these controls are doing, it’s much wiser to stick to default settings as this will be much faster than try to find gain minutes of render time by blindly turning the knobs.
Regarding the zoom, i repeat myself again - please provide an example (rendered image, or screenshot) with the issue, otherwise there’s nothing to advice you, i’m afraid.
Can you please check attached output for noise which i have said ..
I see no noise in the image, only severe over sharpening.
Okay.Thank you for your immediate response.:⁠-⁠)
