Rendering still going on
Hey Corona team !
after months of work on the latest versions of Corona, one thing is still super boring and laggy : no sign when the interecative render is ON.
Before we got the smiley turning, now… nothing.
Sometime pressing stop in VFB doesnt work (because it’s laggy) and reducing the VFP while thje IR style runs crash the scene, or make it super boring to stop especially while working with heavy stuff like scatter of bigpoly geometry.
Did you plan to solve this, and set something ? It shouldn’t be that long as it was there before…?
Thanks,
JG
If you want to cancel the render press Cancel instead of Stop. Stop is still processing other things in the VFB (unless this has changed in vfb2).
Yes I know that Cancel “kills” the rendering thanks :wink:
BRING BACK THE SMILEY :smiley:
The only reason I still use the original vfb =D
Ahaha exactly ! BRING IT BACKKK !
How do you get it back ??
By any means necessary : Interactive Rendering Smiley Return | Corona Ideas Portal
VOTE !
:warning: Record not found
We could not find the record you requested because either:
The record was deleted
You don’t have permission to see the record
Please contact the administrator for this portal if you believe this is an error.
Record not found
[/quote]
Ideas only show on the Portal once they are approved (let’s us check for accidental duplicates, and on very rare occasions simply Decline an idea that can’t happen at all for some reason), so when you first post the Idea the link to it won’t work.
Mm strange…
Look for idea CMAX-I-242
Not strange :smiley: See my previous post.
Ow ok, reply crossed, thanks !
It’s live now :smiley:
Thanks Tom !
Can you explain what exactly you mean by “reducing the VFP”? Also, Corona should never crash, so if it is crashing for you, please contact us about it here: https://support.chaos.com/hc/en-us/requests/new
Thanks!
Well, sometimes when the IR is ON, when reducing the VFB or doing something with the interface like opening render setup menu, or modifying the scene, it’s too heavy change to handle and it bugs.
