Rendering stops after the first fame
Hi guys,
So I have this large file (1.6 GBs), and when I start rendering an animation, the first frame is rendered, then the render crashes with error 700, and after that it won’t render even one frame until I restart the software.
However, when I render each frame separately it works perfectly.
It is very frustrating, I have 400 frames to render and I need them rendered yesterday!
Please Help
Are you using CPU or GPU?
GPU CUDA,
I have RTX 3060 Graphics card, and a Core i9 cpu
Hello @barq_ev ,
Can you please share what is the GPU driver that you have installed? Also, please track your GPU memory consumption while rendering the scene. If you are running out of memory, you can check this article to see how you can optimize your scene.
