Rendering will not stop in DR.
Sorry if this has already been posted but short on time right now to go looking.
So here’s the problem, DR finishes its pass limit/time limit but stays frozen on “Saving/Cleaning Up Scene”. I can’t stop the render at this point unless I close down 3dsmax completely. I would appreciate the help.
I have same problem periodically/
Max frozing with /collecting any extra data/ and crashes
If i hit /cancel/ in window /collecting any extra data from slaves/ max crashes.
This problem has been popping up every so often since alpha 6, some builds do it others do it less.
Super frustrating and can ruin a production if you count on things rendering overnight.
Maybe is the same as in standalone version. Rendering after a while can be stopped but some process is still running in the back unless full process is killed. Guess this bug has never been pinpointed & resolved.
I am having this problem in final release 1.6 and it is very annoying when you have 12 views to render also backburner sucks.
