all features only must work on a small farm in production mode (bucket)
submit jobs to nodes
add remove nodes on the fly
currently batchcam script and backburner is working fine, but you are not able to add a second node after rendering is started. Even you save dr servers by hostnames in the scene.
Current „trick“ is to submit a dr job via batchcam to backburner, one node is taking it and involve a second node via the dr info inside the scene. Now when the second node gets offline or „missed“ the startup the vray_dr.cfg would not be read out during rendering and one node completing the job…
btw what are you using for rendering different stills with light and material variations?
Indeed it is. And should also allow for forms of meetered licensing (pay as you go, kind of.), i think (with us too. but i have *not* checked, as it’s none of my business! :P) .
